Need Sony Part # VCR Capstan!!
T
TA7205
Hi;
Is there anyone that can give me the Sony part number
for the capstan motor in a SLV-750HF ?
I'm fairly certain that the bearing is good. It shows
no sign of failure.
Thanks in advance,
Rick
P
Patch
TA7205 said:
Hi;
no sign of failure.
Thanks in advance,
Rick
Exactly what are the symptoms?
T
Tim Schwartz
Hello,
According to the manual (page 137) the capstan motor (location M902) is
type DC U-26K, Sony part number 8-835-489-11. If you don't know where
to get one, I use Andrews Electronics in California, phone 800-289-0300,
fax 800-289-0301. There are many other Sony parts distributors in the
US, Andrews is just the one I use. The service manual covers the -751HF
and -900HF as well, in case you have a parts machine available to you,
or want to look for one.
Regards,
Tim Schwartz
Bristol Electronics
T
TA7205
I get a blue screen in play mode.
If I tap on the bottom pcb directly under the
capstan motor, the cap. speed stablizes for a second, then black to blue.
I have resoldered the board and connectors.
I have also resolder the connectors and the components on the cap. motor.
I can dectect no "play" in the bearing.
There's no "swish-swish" sound or no disearnable rubbing.
Rick
M
Mark D. Zacharias
I definitely would look closely at all the solder connections underneath.
That cap motor plugs into a large "connect" board, and I've seen bad solder
where the motor plugs in.
Mark Z.
Similar threads
P
Replies
3
Views
1K
Richard
R
L
Replies
Views
715
Uns Lider
U
