Need help in Doing this project ,Electronic code lock
Ebi_90
Mar 29, 2012
5
Mar 29, 2012
5
Ebi_90
Mar 29, 2012
5
Mar 29, 2012
5
Here is the code
#include<reg51.h>
#define port P1
#define dataport P2
#define key P0
#define sec 100
sbit rs = port^0;
sbit rw = port^1;
sbit en = port^2;
sbit col1=key^4;
sbit col2=key^5;
sbit col3=key^6;
sbit row1=key^0;
sbit row2=key^1;
sbit row3=key^2;
sbit row4=key^3;
sbit lock_output=P0^7;
int check=0;
int digit[4]={0,0,0,0};
int dig_input[4]={0,0,0,0};
int dig_input_recheck[4]={0,0,0,0};
int i,k;
void delay(unsigned int msec) // Time delay function
int i,j ;
for(i=0;i<msec;i++)
for(j=0;j<1275;j++);
void lcd_cmd(unsigned char item) // Function to send command to LCD
dataport = item;
rs= 0;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data(unsigned char item) // Function to send data to LCD
dataport = item;
rs= 1;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcd_data_string(unsigned char *str) // Function to send data to string
int i=0;
while(str!='\0')
lcd_data(str);
i++;
//delay(10);
return;
void lcd(unsigned char str[10])
lcd_cmd(0x38);
lcd_cmd(0x0e);
lcd_data_string(str);
void ans()
if(check>3)
lcd_cmd(0x01);
lcd_cmd(0x82);
lcd_data_string(" LOCK OPEN");
lock_output=1;
delay(300);
while(1);
else
lcd_cmd(0x01);
lcd_cmd(0x82);
lcd_data_string(" WRONG PASSWORD");
lock_output=0;
delay(300);
void code_check() // Function to check password
if(i<=3 )
switch((i+1))
case 1: {
if(dig_input[0]==digit[0])
check=check+1;
break;
case 2: {
if(dig_input[1]==digit[1])
check=check+1;
break;
case 3: {
if(dig_input[2]==digit[2])
check=check+1;
break;
case 4: {
if(dig_input[3]==digit[3])
check=check+1;
break;
delay(10);
if(i==3)
ans();
void display(int a) //Display function
switch(a)
case 1:{
lcd_data('*');
delay(100);
digit=1;
code_check();
break;
case 2:{
lcd_data('*');
delay(100);
digit=2;
code_check();
break;
case 3:{
lcd_data('*');
delay(100);
digit=3;
code_check();
break;
case 4:{
lcd_data('*');
delay(100);
digit=4;
code_check();
break;
case 5:{
lcd_data('*');
delay(100);
digit=5;
code_check();
break;
case 6:{
lcd_data('*');
delay(100);
digit=6;
code_check();
break;
case 7:{
lcd_data('*');
delay(100);
digit=7;
code_check();
break;
case 8:{
lcd_data('*');
delay(100);
digit=8;
code_check();
break;
case 9:{
lcd_data('*');
delay(100);
digit=9;
code_check();
break;
case 0:{
lcd_data('*');
delay(100);
digit=0;
code_check();
break;
void check_col1()
row1=row2=row3=row4=1;
row1=0;
if(col1==0)
display(1);
row1=1;
row2=0;
if(col1==0)
display(4);
row2=1;
row3=0;
if(col1==0)
display(7);
row3=1;
row4=0;
if(col1==0)
row4=1;
void check_col2()
row1=0;
if(col2==0)
display(2);
row1=1;
row2=0;
if(col2==0)
display(5);
row2=1;
row3=0;
if(col2==0)
display(8);
row3=1;
row4=0;
if(col2==0)
display(0);
row4=1;
void check_col3()
row1=0;
if(col3==0)
display(3);
row1=1;
row2=0;
if(col3==0)
display(6);
row2=1;
row3=0;
if(col3==0)
display(9);
row3=1;
row4=0;
if(col3==0)
row4=1;
void check_password_col1()
row1=0;
if(col1==0)
dig_input[k]=1;
row1=1;
row2=0;
if(col1==0)
dig_input[k]=4;
row2=1;
row3=0;
if(col1==0)
dig_input[k]=7;
row3=1;
row4=0;
if(col1==0)
row4=1;
void check_password_col2()
row1=0;
if(col2==0)
dig_input[k]=2;
row1=1;
row2=0;
if(col2==0)
dig_input[k]=5;
row2=1;
row3=0;
if(col2==0)
dig_input[k]=8;
row3=1;
row4=0;
if(col2==0)
dig_input[k]=0;
row4=1;
void check_password_col3()
row1=0;
if(col3==0)
dig_input[k]=3;
row1=1;
row2=0;
if(col3==0)
dig_input[k]=6;
row2=1;
row3=0;
if(col3==0)
dig_input[k]=9;
row3=1;
row4=0;
if(col3==0)
row4=1;
void pass_set()
row1=row2=row3=row4=0;
while(col1==1 && col2==1 && col3==1);
for(i=0;i<4;i++)
k=i;
delay(50);
lcd_cmd(0xc4+i);
delay(100);
if(col1==0)
check_password_col1();
else
if(col2==0)
check_password_col2();
else
if(col3==0)
check_password_col3();
lcd_data('*');
delay(50);
void main()
int e,j=0,count=1;
col1=col2=col3=1;
//FOR PASSWoRD INPUT
do
lcd_cmd(0x01); //Clear LCD screen
lcd_cmd(0x81);
lcd("ENTER PASSWORD:");
pass_set();
for(e=0;e<4;e++)
dig_input_recheck[e]=dig_input[e];
lcd_cmd(0x01);
lcd("CONFIRM PASSWORD:");
pass_set();
for(e=0;e<4;e++)
if(dig_input_recheck[e]==dig_input[e])
j++;
if(j<4)
lcd_cmd(0x01);
lcd_cmd(0x85);
lcd("PASSWORD");
lcd_cmd(0xC2);
lcd("NOT MATCH");
delay(300);
while(j<4);
while(count<4) //Code input and check
lcd_cmd(0x01);
lock_output=0;
lcd_cmd(0x82);
lcd("ENTER PASSWORD");
check=0;
for(i=0;i<4;i++)
delay(100);
lcd_cmd(0xc4+i);
if(col1==0)
check_col1();
else
if(col2==0)
check_col2();
else
if(col3==0)
check_col3();
count++;
delay(1);
if(count==4)
lcd_cmd(0x01);
lcd_cmd(0x86);
lcd("SORRY");
lcd_cmd(0xc1);
lcd("NO MORE TRIALS");
while(1);
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
What errors are you getting?
What compiler are you using?
timothy48342
Nov 28, 2011
218
Nov 28, 2011
218
I see the first line of the code is:
#include<reg51.h>
Do you have a file called reg51.h ?
Sid723
Jan 28, 2010
57
Jan 28, 2010
57
The website has a forum and this is posted in the "Contact us" section:
"Contact
We handle technical queries through our Forums only. Any query related to projects and circuits submitted through this form shall not be entertained."
Might want to try the forum and see if you can get the reg51.h include files.
donkey
Feb 26, 2011
1,301
Feb 26, 2011
1,301
and if it isn't that file, could you tell us the errors. that might help us a little more
