T
Time
After a failed lens cleaning attempt our 522 stopped working. It wouldn’t
recognise CDs or if it did would just display 99.99 as track length and
still not play.
So, after a trip to the repair shop and being told to throw it because
repair would cost more than a new one I decided to have a go myself. I
took it apart, noted the pickup assembly (Sanyo SF-P101 5/8P) and ordered
a new one from the UK (I'm in NZ). I removed the old one and replaced it
exactly with the brand new unit; I removed the temporary solder bridge and
turned it on.
Still wouldn’t work…
not exactly the same thing, this time it would just try to spin the CD a
tiny bit clockwise, then spin it backwards about one rev (I'm guessing
this is how it would try to slow the CD, had it been spinning correctly?)
then ‘Er” would display on the display. I've tested all connections, and
everything seems fine. I also tested some of the components such as the
main spinup motor, and during this testing the CD spun up properly! I
don’t get what happened, and I can't accurately reproduce it but the cd
spun up, the display flashed --.-- a few times and attempted to play track
one, but after all these good signs it still ended up with ‘Er’ in this
attempt it also showed 16 tracks (the max that can show on the display at
once) even though the CD in it only had 8.
Does anyone know why this new unit isn’t working, or recognise these
signs? I head somewhere that it might need calibrating/aligning, does what
I described sound like this could be the problem?
Sorry for the long post, but hopefully this way I wont have to post
additional info.
still not play.
turned it on.
additional info.
