P
Peter
For anyone who tried helping me, you wasted your time.
I found out what my problem is - I don't know how to read a transistor data
sheet and understand which leg is which.
I assumed the picture was showing the pin diagram from the top of the
transistor (with the legs on the bottom of the transistor), however, it was
showing it with the legs facing up.
Another words: my transistor is in backwards.
After doing all this research as to why my relay wouldn't work, I came
across two specs I don't understand for the DSP1-DC5V.
It states a pick-up voltage of 4 volts (max) and a drop out voltage of 0.5
volts (min).
To me, that states the relay needs a maximum of 4 volts to turn on and will
remain on until reduced to 0.5 volts. If it's a 5 volt relay, then the 4
volts should state "minimum".
volts (min).
