So I am reaching out to all you geniuses here. First of all I am so thankful I was able to find this site because I am at my wits end! The goal of the circuit below is multi faceted.
- It uses digital relays to switch back and forth from a manual control mode to a control mode run by software. This is the thre ic's at the bottom and that works very nicely.
- LLC is an Allegro Micro 1425 hall effect sensor, used in automotive speed detection implementations. It has two modes, one is that it can count the number of teeth of a ferritic gear as it passes by and the other mode(which is how I am using it, is to detect a single magnetic field as a permanent magnet rolls around on an armature.
- The 4013BEJ is a D type flip flop. It's purpose is to divide the signal from the sensor by 2 and to also produce a nice 50% duty cycle of off and on. This signal is then passed into a Numato GPIO board which drives the associated software. The software itself works beautifully and is well understood. Everything else on the circuit is to support these functions.
- There is a power LED
- There is a signal LED.
- There used to be circuity for an under speed, overspeed and halted alarms
- There used to be circuitry intended to drive a stack-pole for visual indication of current use.
- It is driven with 12VDC which is divided at various places to get specific voltages where they are needed.
