Erm, okay....a synchronous motor has no slip, hence the name. I dunn
where other people are getting their info from, but the answer i
simple
@ 60Hz the formula is 7200 divided by the number of poles (where 720
rpm would bve the theroetical speed of a single pole motor
(hz x 120
---------------- = synchronous spee
num. pole
synchronous speed x percent sli
------------------------------------------ = full-load RP
10
or when variables are known
RPM (SYN) - RPM (FL
-------------------------- x 100 = % sli
RPM (SYN
Does not get any simpler than that. This is easy math, you should no
need to even ask this question....Dunno why this was so hard fo
anyone else to answer...
Percent slip is derived solely from the difference in synchronou
speed vs full-load speed. Slip has little to do with voltage supplie
to the motor, it is a factor of the twist in the rotor'
squirrel-cage. Altering voltage from design voltages alters sli
slightly, but base slip is determined by measuring rotor skew
Frequency has absolutely no effect on slip
Class A motor? I think you might be mistaking your terminology. Clas
A refers to magnet-wire insulation class..
Design A motors are of a normal torque and slip of about 3% and hav
starting currents not limited by NEM
Design B motors have a low starting current, normal slip, and norma
torque. The typical general-purpose motor
Design C has high starting-torque, low starting current, and low slip
This design is usually for sticky loads that are hard to start
Slip does not change much until you get to design D, which are th
high-torque, low starting current, high-slip motors where slip goe
up to 13% or so
Design letters are not a scale of slip, contrary to what seems popula
belief. They are categories for various load requirements as set b
NEM
