Hi, is there any way to test this rectifier with a multimeter if not how can you tell if it's ok?MOSPEC F12C20A Dual Fast Recovery Power Rectifier
Common Anode. 12 Amperes / 50-200 Volts. TO-220AB Case I tried to test it same as regular 3 leg rectifiers and got wierd readings, sort of like a capicator, ( high ohm and bleeding repidly down to no ohm's or 0.5 ohm's. This is one of 3 rectifiers on the secondary side of a ATX switching power supply. Thanks for any info. Jim
