Zdenko wrote...
I need to drive a Power mosfet for 600V, 47 A and it have cca 12 nF
input capacitance. Switching frequency should be a 200khz and with
very small rise and fall time (cca 50 ns).
To evaluate switching speed it's Qgd that matters, more than Ciss.
Qgd is often called the Miller gate-to-drain charge, because it's
the gate charge required as the MOSFET's drain voltage swings from
fully on to off (or back). This corresponds to figure 11 in the
data sheet, and is specified as 121nC typical, which is not bad for
a 415W high-voltage FET. APT's version of the same part highlights
"Low Miller Capacitance" on the front page of the data sheet.
The charge formula tells us you'll need i = Q/t = 121/50 = 2.4A
of gate drive to switch this part in 50ns. I keep an assortment
of FET driver chips to handle different size FETs. For example,
the TC4427 is a dual driver rated at 1.5A, the TC4424 is a 3A
dual and the TC4420 is a single 6A driver. But I'd recommend
the 6A part for your big FET. I'd use a small say 1.5-ohm gate
resistor and I'd keep the FET-driver to gate leads very short.
Keep the return path from the source to the driver GND pin short
and immediately parallel to the gate lead to minimize inductance.
The same holds for the 0.1uF ceramic cap bypassing the driver IC.
I'd start my testing at low voltages and without much load. I'd
evaluate the gate and source voltages during switching to check
the quality of my low-inductance FET-druve wiring. For example,
I'd run the high-side FET with its opto-coupler, but without the
400V on it's drain, and without the low-side switch. In fact I'd
ground the FET's source (to keep gate and source voltages within
range for my scope) and I'd use a temporary resistive load to HV.
I'd pulse the FET on for short pulses (to avoid overheating the
resistor) and carefully scope the lead-inductance spikes, which
will grow higher as the load current is increased. Finally I'd
use an inductive load to evaluate high-current turn-off spikes.
Everything is on high side driver and should be very fast. I
will use appropiate optocoupler if its for low side driver too.
Be careful to maintain enough time delay between turning one FET
off and the other one on! We don't want any high shoot-through
currents at 600V.
- Win
