Hello Spehro,
It's also important to rely on guaranteed data and for Rdson at a
certain Vgs that would be the "max" column. I have seen many designs
where people just took the graph. Worked fine initially. Then another
batch arrived and it was like popcorn.
Of course. Fortunately there are more and more that are guaranteed to
have a certain Rds at 2.5V or even 1.8V. Unfortunately, that usually
goes along with a low breakdown voltage (I've seen as low as 8V, so
the D-S might break down before the gate). Still, the latter provides
a clue for searching, which will help until the people designing the
parametric searches get a clue and make it possible to search for what
you need.
Quite a few devices that are marketed as logic level are too marginal
for my taste.
4.5V ratings are usually safe enough with a 5V supply, assuming a
solid CMOS drive, but not with a 3.3V supply, or with BJT emitter
followers ( a resistor from (CMOS) input to output with the latter can
help with slow switching).
Best regards,
Spehro Pefhany
