- Joined
- Nov 17, 2011
- Messages
- 13,756
This was done using LTSPICE (free) from Analog Devices (formerly Linear Technology, hence LTSPICE)Mind if I ask what program/app/simulator you did this with?
Microwaves normally aren't operated for more than a few minutes at a time, so that may be okay.I am working with will power an 1100 W microwave oven and a 1000 W toaster oven. Not simultaneously of course. The toaster oven will be fine I'm sure but I am concerned that the long duration of peak voltage will burn transformer windings. Do you consider that a valid concern?
Can you approximate some times for the various step levels?The attachment is a very near replication of power out.
I have absolutely no idea what you are rambling on about.PRO RULE OF THUMB... STAY AWAY FROM SINE WAVES!
I do have a kill-a-watt meter. I found that it keeps the landlords a little more honest. I do not have a true RMS meter. I will scope inverter output and include it in an attachment.Microwaves normally aren't operated for more than a few minutes at a time, so that may be okay.
Measuring the microwave current/power with both the mains sinewave and the inverter will tell you if it is drawing excess current with the inverter waveform.
A power measuring device, such as the Kill-A-Watt, is very handy for this purpose.
Can you measure the output voltage of the inverter with a "true RMS" meter (a meter labeled as such)?
Glad you asked. The following attachments are 1. Inverter power out. It appears that this inverter has been seriously damaged. Scope setting is 5 V per division. The signal is about half right. The high side shows +10 V. Low side looks like about -7 V. Also 0 V has been dragged down about 5 V. Maybe the Metal Oxide gate has burned shorted. I am not sure. I just discovered this situation. 2. This is a figure directly from the owners manual. Modifying this inverter is not currently an immediate concern until I repair this unit, if I'm able. I bring power to my inverters directly from the battery bank and not thru the charge controller. That may not be such a hot idea and may have contributed to this device's failure. The first charge controller I used was cheapo. At the moment I do not recall actual configuration I had but due to some shortcomings in cheapo design of charge controller, I think that my PV panel's no load voltage of ~36 V got presented to the power buses. Kind of frightening.Can you approximate some times for the various step levels?
The power out seems pretty stable. V/D = 50 V. A non-true RMS meter reads inverter voltage out as 100 VAC. Inverter supply voltage is 12 VDC. Photos: #1. Inverter Vout no load. #2. 6 Amp belt sander start up. #3. Belt sander free running. #4. Belt sander running loaded.That's about as bad as a 'modified sinewave' can possible get! Only two steps (pos and neg!)
What does it look like under load?
Not so sure that theory will stick for too much longer! Given the supply chain issues and economic consequences I reckon 'repairs' will start making a comeback.I would guess an economics savvy person would explain to me how repairable goods are bad for the economy.
It is indeed a sad state of affairs. I think it was Switzerland that mandated the hours that one could charge their EVs and the electric cars are to be driven only in the case of extreme emergencies. Hopefully our paper currency will maintain a value greater than that of kindling and wall insulation. Think I'll go up to the attic and look for my old buggy whips.Not so sure that theory will stick for too much longer! Given the supply chain issues and economic consequences I reckon 'repairs' will start making a comeback.
