S
sno
Morris,
Here is something I saw many years ago....just remembered it....
http://amasci.com/freenrg/minto.html
Uses flat panels but could be adapted for concentrating.......
Engine rotates at about 1 rpm, fairly high torque...first time I saw it
thought might be able to connect them in parallel, for more torque if
needed...I had thought even at low rpm could pump water....
Think could use water and alcohol for working fluids...
Maybe you could come up with/think of something that could use the same
principal....
Probably something you have already investigated.....<grin>
have fun.....sno
Correct Scientific Terminology:
Hypothesis - a guess as to why or how something occurs
Theory - a hypothesis that has been checked by enough experiments
to be generally assumed to be true.
Law - a hypothesis that has been checked by enough experiments
in enough different ways that it is assumed to be truer then a theory.
Note: nothing is proven in science, things are assumed to be true.
principal....
have fun.....sno
