John Fields
Bell Labs invented the reed relay in 1932 for used in telephone
exchanges. Please explain what switch they used to protect the dry
reed relay switches from having to carry current when opening or
closing even though they had to carry some current when closed. Then
tell me what kind of switch they used to protect the protective
switch ...
http://en.wikipedia.org/wiki/Reed_switch
In fact, it looks as if we are both wrong - the only reference I could
google claims that "dry reed" relays are so called to distinguish them
from mercury-wetted reed relays (which really don't need any wetting
current).
http://www.answers.com/topic/dry-reed-relay?cat=technology
I happen to like mercury-wetted reed relays - they offer a lower and
more stable contact resistance than you can get from any other kind of
relay, and they don't bounce. The fact that they have to be mounted
within 15 degrees of being vertical can be a problem. People kept on
offering orientation-insenstive mercury-wetted reed relays, but nobody
evers seems to have mastered the art of manufacturing them reliably.
Well, Bill, how nice to hear from you again, even though your
commentary is flawed, as usual.
In the second place, manufacturing orientation-insensitive
mercury-wetted reed relays reliably isn't the problem, having them
_perform_ reliably in any orientation seems to be.
In the first place, what's being discussed are contacts used in a
dry _circuit_, not the difference between mercury-wetted and non
mercury-wetted contacts.
Had you had your wits about you when you decided to use Google, you
might have searched for "dry circuit" and found, excerpted from the
National Association of Relay Manufacturers' handbook:
"Dry circuit loads: No current is switched. The contacts carry
current only after they are closed or before they are opened. The
currents may be high, as long as they are not switched. Since there
is no arcing, contact resistance is kept low by using gold plating
or gold alloy contacts."
at:
http://www.leachintl2.com/english/english2/vol6/properties/how4.htm
