Yes Please John - it would be a great help.
OK. View in Courier:
For a basic latch and if there's only one speaker involved you can
use the following if you have a double-pole single-throw
normally-open relay:
| ___ | +--------<FROM AMP
+--O O----+--+ | |
MAINS>----+ | NO | | O | O--->TO SPKR
| | | O--> | O--> |
P||S [COIL]- - -|- - - -|
R||E |
I||C |
MAINS>----+ | ___ |
+--O O----+
NC
To operate it, the NO (normally open) switch is pressed momentarily,
causing current to flow through the coil of the relay and the NO
(normally open) switch, causing the relay contacts to close. When
that happens current will flow into the relay coil through one set
of the relay contacts as well as through the NO switch, with the
result that when the NO switch is released the relay will remain
energized. The other set of contacts is used to connect one of the
wires from the amp to the speaker, (the other wire being connected
normally) and as long as the relay remains latched the amp will be
able to send signal to the speaker. To disconnect the speaker, the
NC switch is pressed, breaking the circuit to the coil of the relay,
which will stop the flow of current in the coil and force the
contacts to disconnect.
If you have a relay with a 5 volt coil, I suspect that's 5 volts DC,
and you won't be able to use that with the AC coming from the
transformer, so you'll either have to get an AC relay or rectify,
smooth, and regulate the output from the transformer in order to
make DC to drive the relay.
Instead of doing that, however, what I'd do would be to start from
scratch with a design using components selected for the job at hand.
Assuming that there will be more than one speaker and more than one
amp, that the speaker impedances (regardless of how they're
connected) won't be less than four ohms, and that any amp won't be
required to put out more than 100 watts means that the relay
contacts can can be rated for a current of 5 amperes. (Or greater)
I'd use relays with coil voltages of 12VDC since they're pretty
cheap and the wall-warts to drive them with are, too. Make sure
that the wall-wart's rated to supply the current for all the relays
in parallel.
For contact configurations I'd go with DPSTNO because that's all you
need, but DPDT may be easier to find or, conceivably, cheaper.
Finally, for a multi-amp, multi-speaker rig, I'd do something like
this:
MAINS>--|~ +12|---------+--------+--+
MAINS>--|~ -12|-+ | O | |
+-----+ | -->| NO | |
WALL | SET | O---+ | |
WART | | | | |
| | | | O | |
| | | O--> | O--> | |
| | [COIL]- - -|- - - -| |
| | | O |
| | LATCH RELAY |
| |O |
| NC |<-- |
| |O RESET |
| | +--------------<FROM AMP1
| | | +--------->TO SPKR1
| | | | +------<FROM AMP2
| +-------+ | | | +->TO SPKR2
| | | | | O | O |
| | | | O--> | O--> | |
| | | SPEAKER RELAY 1
| | +-------------<FROM AMPn-1
| | | +-------->TO SPKRn-1
| | | | +------<FROM AMPn
| +-------+ | | | +->TO SPKRn
| | | | O | O |
| | | O--> | O--> | |
| | SPEAKER RELAY n
