Maytag Neptune PCB R18 value
Galen
Nov 7, 2015
Nov 7, 2015
A friend in Mexico has a couple of burnt resistors on the PCB of his Maytag Neptune MAH3000AWW washing machine. They are R18 and R19, and they're burnt to the extent that they can't be identified. I got a value for R19 of 22K ohm from this forum, but I still need R18. If anybody might have this information, I'd sure appreciate it.
73's de Edd
Aug 21, 2015
3,629
Aug 21, 2015
3,629
Sir Galen . . . . . . . .
Applying a little NASA procedural, using spot averaged digital enhancement and a bit of pixel dithering and we come up with:
Now, of that cluster of interest . . . . of four . . . R11- R 12- R13- R18, we see them also being 22K @ 5%'s also.
For one of them to fry to your referenced extent, must have been the full fury and WHACK of one or both of those 470 ufd @ 200VDC adjunct
filter capacitors, or they possibly are being wired as voltage doublers.
SINCE with only a 200VDC supply, that value of resistor would only be subjected to 1.8 watt overloading, step up to an ~ 400 V supply and
at 3.6 watts , that degree of overloading, is a completely different story.
But he DOES KNOW, that he will ALSO be tracking down the SS device(s) downstream that is /are completely crashed . . .right ?
Thassit . . . .
73's de Edd
Galen
Nov 7, 2015
Nov 7, 2015
Thanks a bunch. And to you questions - he and I both both did not know that some solid state stuff would also be wiped out... but now we do!
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
Galen, the solid-state stuff burned out, .... THAT's what fried the resistors (not the other way around).
