Making parralel circuits with PINS
jujuteux
Jul 15, 2018
6
Jul 15, 2018
6
hi everyone
lately i've been working on making a very simple parallel circuit wich consists of putting 5 elements in parallel
thing is 4 of them has pins
i could decide to cut the pins off to simply solder them but the wires are just THAT small, like half a milimeter thick
is there a safe way to solder such thin wires or some little board already having 8 inputs leading to thicker wires?
thanks for reading
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
No problem soldering wires that small but you need to be cautious that it's properly sized for the current flowing through it.
Solder joints can blow out at higher currents. A mechanical splice is preferred before soldering for that reason.
