Jim Witte
Here's an idea I've come up with in the past few weeks: make a device
that would create a focused, low-intensity ultrasonic field that could
create (hopefully) a "no-cat" zone in front of a computer-monitor for
instance (this is our problem) Two problems I see are:
1) making the signal low-level enough that it would just annoy the cat a
little and nothing more, and
2) figuring out how to focus it. I'm thinking pizoelectric speakers
might be able to do that.
What is the an *upper* limit on what cats can hear? The "focusable
speakers" that I've heard of work by using two ultrasonic signals to
create interferance patterns low enough that people can here them (cats
could be a problem here). Theoretically, the same could be done for
cats, except that the source frequency would have to be higher than the
upper range of the cat's hearing.
Even if an ultrasocnic signal could be made high enough that a cat
wouldn't hear it, could a small enough interference range be created
without also making all sorts of undesirably other interference zones?
Jim
Jim
