R
Randy
Greetings:
About a year ago, I built a small welder. During the assembly of the two
transformers something got my attention. When I connected the two
secondaries in series, I got less than half of the required output voltage.
I switched the output wires and the voltage was there. I reasoned that the
outputs were out of phase with each other and canceled a percentage of the
magnetic field. What I failed to check was the effect it had on the output
current.
Now I'm wondering, can I use magnetic cancellation to my advantage in
controlling current in high power circuits?
To test this theory, I used a small 3volt output transformer and a powerful
magnet to see what effect the magnets' magnetic field had on the
transformer. I tried both poles.
Result: zilch! The voltage didn't even flicker from the 3 volt reading.
However, the closer I put the magnet to the coils, the greater the
vibration. That transformer was dancing across the table like Michael
Jackson on crack.
I'm thinking, the only way to reproduce the cancellation is to run the
output through a magnetic field that is the same frequency but, out of
phase and variable.
This second experiment is just a thought right now. What I'm seeking is
opinions.
An Inquiring Mind,
Randy Gross
current.
Jackson on crack.
phase and variable.
opinions.
An Inquiring Mind,
Randy Gross
