Joerg
Jamie said:I don't use Ltspice or any spice that much however, last night I pulled
something out of my old sketch books and plotted it to LTspice, with a
little change with values to be used for a specific task.
I noticed something strange. As you hover over the nodes, it is
convenient to look at the lower left corner to get information about
that node. Things like voltage, current etc. However, with a specific
drawing(this one), it is showing some off the wall or should I say off
the map, readings in measuring units that are wrong and symbols that
have no meaning for the scale unit.
Not only that, the value that is displayed down there is not even
related to what is at the node but dig this, when
I double click on any of those nodes to show it in the graph above, the
graph is correct, but the bottom view is still wrong, grossly wrong.
Tonight, I popped in a simple drawing ect, it's fine.. But reloaded
this one particular drawing, and it's all over the map down
below?
There must be something in there that is confusing the hell out of
LTSpice?
I have version 4.15s if that helps..
it's not that much of a big deal, I do most of my stuff by hand and a
few other little programs I have lying around here. Just thought I'd
ask to see if any one else has noticed this?
Did you see a submarine plow up the Guadalupe River, with a Chinese
flag? So maybe ...
Just kidding. If it's any comfort, the voltages shown down there may not
mean much. I am doing sims right now and when I hold the cursor to a
node at the top of a 3.3V DC source the text down there reads zero
volts. Of course it isn't real, in the display window later it shows
correctly.
