Looking for micro switch replacement
Discussion in 'Beginner Electronics' started by KZR, Feb 16, 2004.
  1. KZR
    KZR Guest
    I need to replace two microswitches that are in my Porsche spoiler
    assembly. The OEM switches are special Burgess V4NS-9100xx, where
    x=cannot be read. They are pre-wired, moulded SPDT microswitches w/
    peg mounting.
    I found a similiar switch: Burgess 0305A 9100403. It has the same body
    and switch type BUT the plunger is slightly shorter. The mechanical
    actuator in the car does not push the plunger in enough to switch it
    reliably. Bummer.
    So, I need a another switch.
    Any suggestions for online research or ???
    KZR
  2. bj
    bj Guest
    When you say it doesn't switch reliably I take it that it's pretty close
    so it would only take a small extension to either the plunger or the thing
    that pushes
    it to make the whole thing work?? I know its a Porsche ---but
    if you're careful you should be able to do that quiet neatly
    regards
    bj
