that might be a good idea for carrying some of the load during those
planned 3 day outages -- but I wouldnt count on it as part of the load
handling capacity,
I agree. Recognizing we don't yet have enough from the original
poster to go on....
Solar power, when done correctly, is about as reliable as anything
else I've seen.
Unless you have a constant source of sunlight (or equiv), then yes,
you would still need a storage mechanism (batteries, caps, etc..)
Our own product uses solar. Other than the occasional dead panel that
arrives from China, we have ZERO problems in the field. (That
includes ice and snow, BTW) AND, our design can run simultneously via
a wall-wart, though it is never necessary to do so. There's a
blocking diode in the panel, so it's rather trivial to parallel them
with a switcher, etc... You put the regulator downstream. No big
deal.
Note to OP: For onesiew-twosies, try
www.powerupco.com (USA).
They have a pretty good product, and a pretty good selection of lower-
wattage panels.
(Most vendors start at 50W and go up from there.)
HOWEVER, if the poster's application is outdoors, you have other more
important things to worry about which may not be immediately obvious:
#1 - Lightning Damage - which small solar panels definitely do a
better job with IMO.
#2 - Local building codes would likely require a GFCI breaker or
outlet to "wet" locations (i.e., outdoors).
Anyone whose played with these knows about nuisance tripping. (A
solar panel overcomes this.)
#3 - It is often much cheaper to install solar. No electricians, no
permits (usually), etc...
Not to mention, over the long term, it might even be environmentally
friendly!
So, with that said, don't be so quick to rule out Solar.
(I do admit however, that none of this addresses the issue of a 10-
year storage battery.)
-mpm
