Paul Lockwood
- Dec 1, 2014
- 10
- Joined
- Dec 1, 2014
- Messages
- 10
Hi
I'm new to the forum and fairly new to electronics.
To cover a bit of details I'm 45 and an IT engineer which covers all sorts from building / repairing computers, repairing phones if I can, support and some developing / programming.
It must be about 20+ years ago since I dabbled in electronics trying to make the odd thing on a breadboard. Think it may have been a timer.
Recently I've wanted to try and get into this more and been watching several YouTube videos, especially at https://www.youtube.com/user/mjlorton/playlists which has been most helpful on the basics.
I'm also about to order the Arduio UNO Starter kit as this looks quite interesting and the programming side will also be ideal for me too.
I would gladly welcome some comments on the Arduino side as I believe it is quite a big thing.
One project I do have in mind is as below which any help would me much appreciated.
For our phone system at work I've setup some laptops that produce live reports for the call centers so that they can see the calls coming in etc. I have some alerts on the report that basically can highlight a small part of the screen in a colour and also play a wav file to alert them of a problem.
What I would like to do is produce a more visual alert in the way of a flashing light which will light up over 6 desks (2 rows of 3 desks) so it needs to be reasonably bright but not blinding.
I had thought of somehow making a circuit to gather when the audio on the laptop plays a wav file, i.e.. plug into the 3.5mm jack on the laptop (will have to be a splitter so that the other half goes to some speakers to still play the audio). When the audio is triggered the circuit would then allow a light to be illuminated, the main issue here is that the sound being played is a short sharp boxing bell that rings once and I would like a light to either flash or just illuminate for a set time like 5 or 10 seconds.
I'm hoping I'm not asking too much or posting in the wrong area, but any assistance would be most appreciated. It would be nice to have an explanation as to what the circuit does rather than just be given a solution as I find that if you have a goal you learn better than just doing examples etc. that you can get that are not relevant to your needs.
Thanks in advance for any assistance.
Paul
Paul
