jasen
But you have an ethernet connection between your router and modem, so
I would think it has an IP address as well -> the assigned IP address
from your provider. But then, it only passes on packets, so it doesn't
do you any good It may have diagnostics, but perhaps not accessible
through a tcp/ip connection and a common protocol.
I don't think PPPoE uses IP...
isp home modem router
. . . . . . . . . . LAN
ADSL \ \ . . Ethernet . . ethernet
PPP ---------\ \------------ ------------- ---------
IP --------------/ /--------------------------------- |
IP isn't the only network service than can be provided over ethernet
or over PPP for that matter.
Often (but not always) a device that combines the modem and router
is used. Using a separate modem can reduce hardware cost in extreme
situations where cheap modem/routers get "gummed up" and need to be
reset.
We had a modem-router at work that would stop accepting inbound
connections at random times, we switched it to modem only mode
("passthrough") and used a linux box to do the ppp and router
function. Reliability has improved.
