Hi Folks,
I was testing some 650nm GaAs/AlGaAs LEDs when I found a batch showing this very strange IV curve (attached) with current driven negative resistance. Any idea what is going on
The affected LEDs have all an unusual higher forward voltage. Even up to 4V for 1mA instead of a regular 1.8/2V for my processed LEDs
The negative resistance curve has a threshold-like behavior. Increasing just few mA brings down the Voltage of roughly 1V (from 5V where the threshold seem to be) and increase current from7/8 mA to 20/25mA
Light Output is bigger before the NDR takes place, suggesting some sort of tunneling but I have no idea where ...
Increasing the current above 40mA rectifies the IV curve, brings back the curve to a textbook graph, decrease the initial higher forward voltage of a couple of Volts, but also decrease of 50% light output at 1mA (I believe simply because I am pumping too much current in my very thin hereto junction)
Any helps or advice would be useful. The structure of the LEDs and metalization has nothing fancy at all, just regular stuff for this kind of red LEDs
Please Ignore the lines at 2V in the picture. Is just an artifact created by the machine!!
