led heartbeat
MadBoy79
Nov 30, 2012
15
Nov 30, 2012
15
hi all
i need from help .
I want build simple led light circuit - something like this
and if his circuit to change the frequency .
Thank you in advance.
MadBoy79
Nov 30, 2012
15
Nov 30, 2012
15
I'm looking for a scheme that turns on and off with this LED effect - compared with conventional multivibrator 555.
When I use the red Power LED and Built-in plastic heart - the effect will be great :)
CocaCola
Apr 7, 2012
3,635
Apr 7, 2012
3,635
Did you bother taking 5 minutes to follow the link provided by Steve to Kris' design? Probably not based on this response...
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Beware that the circuit you've shown us has unused inputs of the 4017 left floating.
This is poor practice and you should tie them somewhere. Check the datasheet and tie reset to wherever DOESN'T reset the chip, and enable to wherever it DOES enable the outputs.
CocaCola
Apr 7, 2012
3,635
Apr 7, 2012
3,635
On that note there are also other problems with pin 13 and 15 left floating (noted above), as shown you will not get reliable results, it's really a roll of the dice on what it will or won't do with any particular start up...
(*steve*)
25,510
25,510
Cool!
It may be better if you could diffuse the light from the LEDs a little more, but unless you're looking directly at them, the effect seems nice.
cjdelphi
Oct 26, 2011
1,166
Oct 26, 2011
1,166
a 3rd option is to use a micro controller.
it would be only a few lines long and only a very basic chip would be required to do a heart beat effect and a whole lot more..... (eg, attiny85 or a PIC)
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
The circuit refered to in #14
The 4017 has its outputs almost shorted to ground. This may be too much for it. Put a 1k resistor in the outputs to limit the current.
A capacitor across the power supply would not be disadvatageous.
MadBoy79
Nov 30, 2012
15
Nov 30, 2012
15
That heart beat one seems to be a very wasteful circuit
http://img822.imageshack.us/img822/6900/ledheartbeat1fading.jpg
Sorry I forgot to show the version of the scheme.
The picture that comment - scheme gives errors and does not work.
After using a diodes and capacitor in parallel with the LED bar = scheme is working not even stop for a whole day.
http://img841.imageshack.us/img841/6562/ledheartbeat1lastversio.jpg
in the first video I did not use a capacitor.
