I'm working with a microcontroller that will control a solid state relay that will be used to control automotive lighting.
I am confident I have enough knowledge to get this half of my circuit done, but I am struggling with how I should tackle the lighting side...
My goal is to make my controller compatible with any other lighting product, which means I will be switching 12-14.4V on and off. This will require me to make my own LED lighting modules that accept this an in input voltage.
I struggle with SMD components and wish to keep the component count low.
I will be using 1W high power LEDs that will require 350mA, and some square LEDs that require 70mA.
They will not be mixed, I am making a puck with 3-5 of the square LEDs, and a puck with 2 or 3 of the 1W LEDs.
-I can get away with using a resistor and calculating the values based on a 14.4V supply (and slightly underrate the LEDs to help them last longer) but am concerned with heat, and longevity of this method.
-I can construct a basic analog constant current supply that I had found online at http://www.instructables.com/id/Power-LED-s---simplest-light-with-constant-current/ ... but again, am concerned with heat generated. I greatly prefer the controlled power source though)
-I have started looking at switching power supplies... but have been presented with solutions requiring lots of parts that I don't completely understand. I like the sounds of this method as it will keep heat down, and allow for a controlled powersource.
I was hoping I could run this by someone with more experience to find if it is worth trying to over complicate this keep heat down, and keep the LEDs running hopefully longer. These LED modules will operate in 2 states, Constantly on, and flashing... so any method I choose will have power cut, and re-applied at no faster than 30Hz.
Will the flashing cause issues with a linear or switching power supply?
What are your thoughts on how I should power each LED puck?
