S
Steve Oakes
Hello,
I purchased several sets of Noma LED Faceted C7 - 50 light sets to
decorate a large tree I have. I realize these lights aren't as bright
as the traditional C7 lights, however they are supposed to last 25 times
as long as a traditional set and use far less electricity (2.4W for 50
lights vs. 124.8W for a 25 light traditional set. I figured I'd give
them a try. The strings can be connected end to end, however there is a
warning label on one end which states not to connect more than 3 strands
together at a time. My question is: Why can't I connect more than three
2.4 watt strands together? If I hooked 10 strands together, I would
only be using 24 watts of power total, not enough to blow a fuse or over
heat the wiring. Does anybody know the answer to this question?
Thank You,
Steve
Thank You,
Steve
