Bluestribute
- Nov 15, 2011
- 8
- Joined
- Nov 15, 2011
- Messages
- 8
http://www.tonepad.com/getFileInfo.asp?id=119
First off, I have to use an IC with 14 legs not 16 as it has. Anyways, I just want to make sure I'm reading this schematic correctly (making the Tube Fuzz)
Connect .1µf capacitor to leg 14 of the IC
Connect 10pf capacitor also to the IC (?)
Connect 100k resistor to 10pf capacitor
Connect the 10pf and 100k to the 1M resistor
Connect 10pf to leg 13 of the IC
That's how I've been interpreting this (I won't list all connections I "see", that's just the first part) and wanna make sure I'm doing it correctly . . . I know the dots are where you connect the wires but what if there is no dot, and what if there isn't something on the other side of it (ie look at the 10pf capacitor and also the 100k/.1µf connection)? That's the main problem I'm having
