Duh!
I've NEVER claimed to have any electronics expertise, what-so-ever. Never.
So this would be an oft used Usenet tactic, Vis-à-vis;
a) First, manufacture a claim and then infer that the other combatant made
it.
b) Then others may use that false claim as a justification for further
criticisms, attacks and/or allegations of arrogance, pseudo intellectualism,
whatever. At this point it is open slather.
c) Never-ever concern yourself with the truth of what claims the other
combatant did ACTUALLY make about their expertise or lack of it. This would
be sheer folly and may lead to the loss of the argument.
Regarding your suggested methodology. Making the suggested measurements
reveals nothing unless it is done during periods of voltage overload. So OK,
I could pull the DMM and quietly sit there and wait for a hours, perhaps
days, poised with my probes at exactly the correct location and angle and
just wait for something to happen.
Yes, I could do that, if I was a creation. Well done.
Regarding your assertion that I don't know "how challenging it is to design
and implement what you wanted". Well I certainly don't know how difficult
it is for YOU.
As it happens, I am one of the few contributors here who has ACTUALLY
suggested a viable and cost effective solution to my own request. Go on,
look back. I DARE YOU.
I am not being conceited here, I actually EXPECTED that I could get a better
solution from someone here.
Re: Your analogy. Could I suggest you reproduce it in another post and I
will go over it with you, point-by-point. This post is already approaching
an unmanageable size and in any case your 'analogy' amounts to little more
than 'white noise'.
Re: Bob's advice. It may be good advice. The likelihood of getting any
useable information from a .Usenet thread is inversely proportional to its
length. So the longer this goes on, the more likely it is good advice.
Also, I don't know where you got that 'Pre-amp' presumption. Certainly not
from me.
You reckoned that if I was being honest I would say "Actually, I built the
engine, it's running badly, does anyone want to buy some really good fuel
filters?"
The natural presumption from that statement is, according to you at least,
that I would be dishonest if I claimed:
a) Not to have built it,
b) That it is running well (except during periods of over supply)
c) That I don't want to sell my caps.
However, all those things are true. So that is the first reason why your
analogy is fucked up and arse about.
I made no claim about making it, or designing it for that matter. I did tell
you that I had swapped some capacitors, which is only a minor modification
at best. I was a little surprised that nobody suggested checking for dry
joint(s) on the caps, but hey, that is your prerogative.
Regarding this statement: "I thought my insightful analogy would help you
understand why people responded to you with derision".
I developed my own theory, days ago. Read my functional description of the
supposed club of 'deciders' that I have dubbed 'Phil-o-philes'. My theory
much stronger that yours because, like all good theories, my theory is based
on verifiable, empirical observations of facts. (i.e. when Phil inferred
that the power to "get to decide what others accept or believe" exists as a
right that some people may hold others not. To make such a distinction, he
must believe that the power a) ACTUALLY exits b) is assignable to various
individuals and to the exclusion of others, which is as much as saying, he
believes it exists as a RIGHT. He didn't say on what basis this right might
be bestowed on individuals, but we can only assume it is earned by
displaying superior knowledge or experience.
On the other had, your analogy is based on what? Three complete falsehoods
for a start and then no empirical observations that you have elucidated thus
far.
Your analogy is NOTHING more than OPINION, masquerading as analysis. Perhaps
you may develop it into something more useful, but thus far it has the
appearance of analogy by a 'petrol head', and nothing more.
Regarding your apology: I will give it my consideration.
Poxy said:
Mark said:
Well, I didn't think of searching for the '7815 datasheet', so fucking
sue
me.
That shows that you are not experienced in working with electronics -
anybody who regularly does searches for component numbers would
automatically add "datasheet". Furthermore, anyone with electronics
experience would understand the operating characteristics of a common
linear
regulator without needing to refer to a datasheet - it's really common,
basic stuff.
Either way, the cheapest solution is sounding like I should exchange the
7815 /7915 pair, for a pair that DOES have that 30V spec. and in so
doing,
eliminate the possible cause of the observed clipping during voltage
overloads.
The first thing to do is measure voltages at key points - at the output of
the AC plugpack at the input of the regulators, at the output of the
regualtors etc. Boring I know, but that is how you start the diagnosis a
power supply problem. That you don't appear to realise that really basic
fact demonstrates a lack of knowledge and experience with simple power
supplies and suggests that you're not equipped to diagnose nor fix the
problem.
Also, I take umbrage (offence, to you) at your trite analogy. It isn't
an
accurate portrayal of what happened or my actions or my motivations or my
attitude. I would welcome a point-by-point comparison of your analogy and my
behaviour.
My analogy, horribly misspelt as it probably was, was reasonable, if not
as
amusing as I would have liked. You clearly don't get how challenging it is
to design and implement what you wanted - it's *really* complex stuff. By
comparison, getting a standard dual-rail, linear regulator power supply to
behave is trivial.
The more I think about it, Bob's advice is correct - you should get
someone
with a solid background in electronics to fix your preamp for you.
Your PRESUMPTION that I must pay too much for my Black Gates is based on
what? An ASSUMPTION that I pay foolish prices. That is both insulting AND
ignorant (of how cheaply Black Gates can be purchased).
Hey, if they give the sparkling audio performance you like, fair enough. I
probably haven't paid enough attention to the musicality of the caps I
buy.
I also take umberage to your allegation that I am not "being straight-up
with [this group]".
You reckon that if i was being honest I would say "Actually, I built the
filters?" Here is why I wouldn't say such a thing:
a) I didn't build the application, I modified it.
You never said that. It does explain a lot. In my analogy, it would be
like
revealing that you'd modified your engine while at the same time giving
the
strong impression you don't really know how engines work.
b) It isn't running badly (under nominal conditions), it sounds superb.
c) I am not SELLING anything.
That was a joke. Sorry. I was kind of thinking that if your "thing" didn't
end up working, you could recover some cash-money by Ebaying them fancy
caps.
I look forward to our point-by-point comparison of your analogy with my
behaviour. I can't find many comparisons at all. Do you do this often? (that
is: make up stupid analogies that just don't work).
Look, I've got nothing to add. I thought my insightful analogy would help
you understand why people responded to you with derision. Obviously you
still don't get it, and that seems to be because you don't have the
knowledge and experience in electronics to diagnose and solve the fault -
everything you say reinforces that fact.
Get someone who knows what they are doing to look at your device. If it's
a
power supply problem they'll diagnose and fix it very quickly.
And you might be able to pay them in capacitors
