Three years ago KrisBlueNZ - RIP - kindly produced the following circuit for use on my 24 volt boat. The problem was back emf destroying contacts in the pumps pressure switch. This circuit completely solved the problem and 3 years later it is still in continuous use.
2 friends of mine are suffering exactly the same problem, but with 12 volt pumps. These pumps are rated at not more than 6 amps. Would this same circuit work on 12 volts or should components be upgraded?
Many thanks, Stu
Many thanks, Stu
