D
I am thinking of getting one of the cheap inverters now available from
Jaycar/DSE etc to run my Acer Laptop. The Laptop PSU puts out 19V at
3.16 amp, which I make = 60W.
What puzzles me is that the input is rated as 100 - 240 Volts at 1.5
amp. Can I safely assume that this would be the current at 100V and
that at 240 Volts it would be substantially less ? From the size &
weight of it, it is obviously a switch mode unit and doesn't run
terribly warm.
I am hoping to run it off a 100W modified sine wave inverter - I
believe that Switchers are quite tolerant of modified sine wave ? Can
anyone confirm this or does anyone know of any problems with doing
this ?
I realise that it would be more electrically efficient to build a unit
to directly convert the 12V supply to 19V, but given the small amount
of time I intend to use the unit, I can't justify the time & I suspect
it may be as expensive as a cheap 240V inverter.
TIA
terribly warm.
this ?
TIA
