Just a few comments, interspersed below:
RodneyBritt wrote
I have done a significant number of commercial installations, Banks etc
included. I have used the four conductor method and had end of line inside the
panel. Never had a problem.
This reads like you're using a single 4 cond. cable, containing both the
feed and return wires. Is that correct?
I have also done many bank installs as a subcontractor, but cannot remember
ever having the system inspected by UL, or anyone else for that matter.
The advantages of having spare conductors
shouldn't need any clarification.
Well, are they spares, or returns for the eol?
As per using the same jacket? I don't on
commercial installs and do on residential installations.
Above you said " I have done a significant number of commercial
installations, Banks etc included. I have used the four conductor method
and had end of line inside the panel. Never had a problem."
Presumably, "the four conductor method" as you say, is the one being
discussed in this thread; the one where both feed and return wires are
contained in the same jacket. Are you now saying that you use 2 cables in
commercial installations?
Here in Telluride the
homes are very very expensive and the last thing anybody wants is to tamper
with the finished product .
What do you mean? Once installed, no future repairs are desired?
Case and Point, The door jams out here are very
pricey. The owners nor their represenatives want the contact removed once
installed.
Why not? The fact that the door jambs are expensive should reinforce the
proper installation practice of making the contacts removable, and their
connections easily accessible without causing damage to the frame.
Having the EOLR inside the panel and as end of line
supervision.....as one put it extended does nothing to remove the value of the
alarm installation itself. The scenario of staping two conductors and then the
other two has never crossed my path in my entire life. However, I have had to
replace hundreds of panels over the years, replace resistors, modify zoning
to fit new owners and etc etc.
I don't dispute that spare conductors are a good idea. I also don't happen
to believe that eol resistors are practical in most residential
installations. I do use them in screens, and in certain other applications.
I have also used the 4 conductor method myself. You need to know however,
that putting the eol at the device will be more secure than using the same 4
cond. cable for both feed and return.
I don't agree with the voices of dissent. U.L
inspections have never failed my installations based on this principle..
What installations have you done with the 4 conductor feed and return method
(1 cable) which were UL inspected?
So, I
guess there are those that can't see the benefits...but then again not all are
equally experienced.
The only benefit is convenience for the installer. The fact that you
believe this method is better does not mean that you are more experienced
than others, but rather that you have an opinion not shared by other, more
experienced installers.
js
