David Farber
I have an automatic gate which uses a GE 5KH36HN62T motor to open and close
the gate. The gate intermittently will not open. You can hear the motor buzz
and it will start moving if given a gentle push. The motor uses a capacitor
start circuit to get it going. The other fault with the motor is that
sometimes it turns in the wrong direction. This is my analysis of the
situation so correct me if I'm wrong. The fact that the motor buzzes and
will start turning with a gentle assist probably means there is a fault in
the start circuit. I tested the capacitors and they are ok. So I'm thinking
the internal motor start switch is sticking open. As far as the motor
occasionally turning the wrong direction, that too can be attributed to the
faulty start circuit because not only does the start circuit get the motor
going from a stopped position, it determines the direction that motor will
turn. If the load is light enough, the motor now may turn in either
direction if the start windings are not giving it its initial boost. Does
this make sense?
Thanks for your reply.
this make sense?
