First of all, I am newb here. So, if I am violating any sort of forum protocols, I apologize in advance. As well, I am very grateful for any insight that anyone might offer.
My question is this;
Is there any sort of circuit out there, (preferably passive but I could supply a 12-14V+ DC if needed) that would allow the resistance on a wire to increase by a percentage?
My problem is that I have a sensor in a 12V+ DC automotive system that is "underoutputting" for the calibrations of the visible gauge. That is, the resistance on the sending unit is not as high as needed for any given position.
For example if the gauge is expecting a value of 50 ohms on the wire in order to read the mid point of say 100 degrees, the sending unit is only providing 40 ohms when the condition of 100 degrees exists. So, the gauge is not accurate.
Before you suggest simply adding a resistor in series, note that the sending unit doesn't behave in a linear way. I have run some tests, and ideally, i would like to increase the resistance on the wire by 15-20% at any given position of the sending unit.
Other restraints are that I cannot access the sending unit itself. I can access the gauge. It is a standard automotive style with a 12v+, a ground and the wire from the sending unit.
Lastly, note that there is no expectation that replacing the sending unit would result in better performance. It is a known issue with the system. I just want to improve the reliability of the information from the gauge.
Also, I am fairly dexterous, can solder well enough to get electrons to flow and not burn down anything, and I am smart enough to know that my chances of help here are far greater than at any automotive forum, but I don't have a great deal of experience reading circuit diagrams, so dumb it down as much as you can. Many, many thanks in advance.
