R
Russ
I have been searching for a long time for a device that will test
digital and analog ICs in circuit. I have seen some old ones but I
would like something newer. Something with a USB port that you can
hook up to a computer would be great and the ability to add devices to
the list is a must have. There has got to be something out there. I
would like the price to be under $1000.00. I have so many boards that
I look at and think "Is this chip working or not" Some boards I can't
apply power to. It would be nice to be able to have adaptors for the
newer SMD device and a 48 pin ziff socket also. I have a Huntron with
a HSR-410 but I don't always have duplicate boards or chips to compare to
But I would think there are other companies out there that
make something like this. Now I have searched google for hours, day
after day, for a long time. So I have seen pretty much anything that
comes up with a related word search using google. So unless I missed
something someone is going to have to have experience in the
electronic troubleshooting field and maybe worked with something similar.
If I was smart I would make one.
I have seen many out of circuit checkers. And like I mentioned some
old discontinued devices that check digital IC chips in circuit. I
also have the HP Comparator but that has so many limitations. I would
like this device to have most chips stored in memory and you punch the chip
number in and hook up a clip onto the chip that is in circuit and it
runs some tests on it, with and without power. For both digital and
analog and other types of devices. Has anyone seen anythink like
this?Thanks for the help.
