flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
I have a supply connected to a load. The load is a constant purely resistive load. The supply voltage fluctuates fairly wildly and is capable of supplying a lot more current into the load, than the load is capable of surviving.
I could add a fuse in series and that would impose a specific limit on the current which was allowed to be supplied to the load. But, it would involve the cessation of operation when the fuse blew.
I want a component like a fuse that will sit there passing current up to a certain value, but once that value is reached, it maybe increases it's resistance to keep the current down. Impose a current ceiling rather than just blow.
I heard of using NTC thermistors to limit transient high currents but the transients I'm dealing with last minutes, maybe hours rather than milliseconds or seconds.
It's solar panels feeding into a charge controller - most of the time here in the UK it stays averagely grey but you get these odd half days where the sun randomly has a party, last time this happened my solar system, which had been working fine for weeks under average / usual weather, suddenly melted in a heap on the floor.
I'd rather just miss out on the best of the very rare days of extreme power availability, than spend orders of magnitude more on charge controllers, or have to keep replacing fuses.
I guess failing a completely automatic option, a manually resettable breaker of some kind would be better than nothing. I just wondered if there was a simple 2-wire component that would sit there passively and hold passing excess currents down, whilst not impeding currents below the ceiling.
I saw these https://en.wikipedia.org/wiki/Resettable_fuse but I wondered if I'd be able to get them in a sufficient power dissipation, and whether the perhaps not insignificant resistance below the threshold current would cause efficiency problems under normal operation?
I saw a jfet used as a current limiter by connecting it's source back to it's gate (?) somewhere.. does that sound feasable
I have solar panels capable of producing, under the sunniest of conditions, maybe 900W; whereas the controller's PV input is only rated at 480W. 95% of the time the panels only produce two, maybe three hundred watts but then you get these very occasional spikes right up toward the 900's.
So I guess I need something capable of potentially 'throwing away' 400-odd Watts under the brightest spells
Thanks for any thoughts.
