Identity a SOT-23 transistor marked MO5 or M05
Jonathan Schneider
I'm fixing a laptop and am trying to identify a transistor which I
believe may be popped. Well I assume that's what it is. It has all
three legs connected.
It is SOT-23 and marked MO5 or could be M05 (letter Oh or digit zero).
There are a couple of others onboard and I believe it's part of the
power supply.
Any ideas ?
Thanks,
Jon
Jonathan Schneider
Best guess is not a tranny but a dual zener (like part WOST05C) with
common anodes on the middle pin. Probing others onboard adds credence
to this though I'm very much open to suggestions.
Jon
F
Franc Zabkar
Jon
I haven't checked all of the following, but they appear to be similar
parts with the same marking code:
http://www.microsemi.com/datasheets/MSC1378.PDF (SM05)
http://www.secosgmbh.com:8081/datasheet/products/TVS/SC-59/SMD03C~SMD36C.pdf
(SMD05C)
http://soft.laogu.com/datasheet/103/PJSMS05_PANJIT_87495.pdf (PJSMS05)
http://www.datasheet4u.com/html/S/M/3/SM36TC_SemtechCorporation.pdf.html
(SM05)
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-40/DSA-791422.pdf
(WOST05C)
- Franc Zabkar
N
N_Cook
Michael A. Terrell said:
They generally use code numbers, not part of the actual number. There
are a couple databses on line like this one to help identify SMD semis.
http://www.marsport.org.uk/smd/mainframe.htm
http://improve-usenet.org/index.html
aioe.org, Goggle Groups, and Web TV users must request to be white
listed, or I will not see your messages.
If you have broadband, your ISP may have a NNTP news server included in
your account: http://www.usenettools.net/ISP.htm
There are two kinds of people on this earth:
The crazy, and the insane.
The first sign of insanity is denying that you're crazy.
Are manufacturer's allowed to put whatever code they like on devices ?
So is it possible to have 2 functionally different devices (on same
package?) with the same code ?
