Identify component L2
davenn
14,271
14,271
I have found a short circuit on the component L2 but I don't know what it is? it looks like a diode..
Thankyou @kellys_eye , finally a correct answer is given
Yes, it a 1/2 turn ferrite bead, and as Kelly-eye is used for suppression .... generally noise /RF suppression on a data line or a power rail
The top (Black) has come from L2 and reads as a resistor, and the bottom which looks like a resistor is the one that reads as an inductor?
the green bodied part is also an inductor but it's going to be a multi-turn coil
Brown Green Red
1 5 00
not sure if that is going to be 15uH or 150uH ??
cheers
BillyWhiz
May 22, 2023
18
May 22, 2023
18
Hi Kellys Eye,
Thanks for responding, it was just that I was checking through a PCB and found it was reading short that I suspected it to be faulty.
Harald Kapp
13,756
13,756
Not every short is a fault. Believe it or not there are actually 0 Ω "resistors". used e.g. as links to enable (or disable) certain circuit functions.
Delta Prime
Jul 29, 2020
2,026
Jul 29, 2020
2,026
Future reference this is the schematic symbol and or designator on a PCB for ferrite bead.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Hi Kellys Eye,
I understand what you came across and why your thoughts went in that direction but it also illustrates the old adage - "if it ain't broke, don't fix it"....:)
Delta Prime
Jul 29, 2020
2,026
Jul 29, 2020
2,026
Yin and yang.
I disagree .if it's not broke all that means is, it does not have enough features. :cool:
BillyWhiz
May 22, 2023
18
May 22, 2023
18
Hi Guys,
I am trying to fault find a Microwave PCB so i am testing components to see which are faulty...:rolleyes:
Delta Prime
Jul 29, 2020
2,026
Jul 29, 2020
2,026
Hi Guys,
I was just teasing it out of you. (pun intended).
Make,model,of microwave please.
I will see if I can't grab a schematic for you.
Delta Prime
Jul 29, 2020
2,026
Jul 29, 2020
2,026
Now you're teasing me,that info would be nice, while I'm looking for the schematic can take another photo thank you
BillyWhiz
May 22, 2023
18
May 22, 2023
18
The Microwave stopped working as nothing happened when we pressed any of the buttons. I opened it and found that most of the buttons needed replacing. After that when pressing start the magnetron did not operate, I checked all the door switches and they where fine, it appeared that the board was not supplying voltage to the magnetron. I found the EE16transformer not working, and I am awaiting the new part arriving. So i decided to check through the rest of the board for other faults.
Delta Prime
Jul 29, 2020
2,026
Jul 29, 2020
2,026
Haven't forgot about you.No schemo. You're good with the soldering iron so. Be careful with that magnetron. work gloves while handling it. And a face mask. And look up the dangers of handling magnetrons. We'll go to the power supply if you can take photos we'll have to work off of that & a multimeter. And please do not jump the gun and turn it on.
Just follow the power cord into the microwave and take photos. thank you :)
BillyWhiz
May 22, 2023
18
May 22, 2023
18
Ok first picture is the incoming supply.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Most microwaves that have 'digital' circuits (keypad operation, not the simpler rotating mechanical timer versions) have a defined supply for the electronics (5V) that frequently comes via a capacitor dropper/rectifier/regulator (sometime an SMPS) system.
We would need to see the actual board that has all the electronics on it.
The rest of the machine is basically relays, switches and the transformer/magnetron. This side of it, assuming the magnetron isn't knackered, is usually unbreakable but the power supply to the electronics suffers from the same 'blown capacitor' issues that many such power supplies do these days.
Show us the control board.
BillyWhiz
May 22, 2023
18
May 22, 2023
18
Okay here is the circuit board with the small EE16 transformer missing as I took it out to test it. It shows faulty on the meter!
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
In what way is it showing 'faulty'?
In these circumstances it is usually the controller IC (IC1) that has failed. It 'might' have taken out the primary of the transformer but that's a very, very rare occurence.
