I need a Wiring Schematic for a 2/12/75 amp charger switch
Duane Jones
May 21, 2016
May 21, 2016
I have Schumacher 2/12/75 charger. I need to replace the amp selection switch. A schematic of the switch would help.
Kiwi
Jan 28, 2013
472
Jan 28, 2013
472
Duane,
Have you tried contacting Schumacher for price and availability of the correct new switch?
801 BUSINESS CENTER DRIVE • MOUNT PROSPECT, ILLINOIS 60056-2179 •-800-621-5485 • Ext. 322
3,633
3,633
Sir Duane Jones . . . . . . .
You gave us no model, but is this it ?
That specified part is color marked up on both schema and parts list.
Quite a special little slide switch there, with its 3 positions and do note the cross jumper used on the middle terminals, should you opt to use another switch.
But don't let the marked in ends specified 75 A fool you, as that is being relevant to the secondary of the transformer power handling, and its short time delivered power.
A 10 amp AC rated switch would work fine there and over in the 2 amp mode portion . . . .that little switch end would be asking . . ."Are you turned on yet ? "
STAAAAND WAAAAAY BACK ! . . . . . . .Here it is . . .
Duane Jones
May 21, 2016
May 21, 2016
Duane,
No I have not tried that. I was trying to invent my own switch. However, buying one would be more economical and wiser. Buying one is easy - I seldom do things the easy way.
