how to bypass dremel tool internal variable speed control?
E
Ed Huntress
Gerald Miller said:
Check the front of the refrigerator.
Gerry :)}
London, Canada
Then, thank God for magnetism, too. d:cool:
C
ChairmanOfTheBored
john wrote:
Interesting. What package types were susceptible to this (or did it
matter)? Metal can TO-x ICs seemed to be the most reliable (RTL, HLL,
some DTL, etc.) but I found a lot of early ceramic packages suffered
from bad seals and permitted fungi to enter and grow inside (this
in equipment that had never been wet, just from operating
environmental conditions). These parts seemed also to lack proper
passivation internally.
Air is also capable of introducing an ESD event. The tribo-electric
effect.
Air is an insulator. Drag molecules of it across an isolated device
(read blow), be it conductor or otherwise, and it WILL gain charge. Touch
to ground, and there is a discharge.
Nearly every "air station" one will find in a proper electronics
manufacturing facility will be at an ESD, properly grounded workstation
so that such discharges only occur at a slow rate. The "air tool"
operator is also supposed to remain grounded through a properly
constructed ESD grounding system. Either heal straps on an ESD matting
or floor set-up, or wrist or smock strap versions.
C
ChairmanOfTheBored
The ceramic Ic's were supposed to be more reliable but in fact as you
said they had a higher failure rate. The sealant that they used was not
too good since in many instances the tops would come off the IC . I bet
the sealant was probably a little corrosive too.
Silver filled epoxy is the main chip bonding media. The air must be
evacuated from it in proper use. The surface of it will "tarnish" after
application.
We use "humiseal" on our applications.
The first generation of IC's had a very high failure rate in compared
to todays products.
Epoxies have come a long way since the sixties.
They were very heat sensitive and would act up
above 100 degrees F even though the rating was higher. If I found one
bad ic I would just change out every IC on the whole board that had the
same date code and install a second generation ic with the same number.
Don't know if I would have gone that far, but whatever.
On some equipment you would automaticly change out a couple of parts
and it was fixed. One company insisted on using the cheapest parts
available but their advertising sold a lot of equipment in spite of the
poor reliablity of the product. Today ic's and transistors , other than
high power transistors, almost never fail unless something external
blows them out. The industry has come a long way since the fifties when
I first started in electronics.
The first IC chips were in the sixties. TI made them for Fairchild,
and they went into missiles. Ten transistor elements.
Now, we have 200 Million plus transistor elements on a single die.
I think we are doing pretty good..
D
DoN. Nichols
According to krw said:
snyder.on.ca says...
Shouldn't be too bad today. Twenty years ago, when people smoked in
office buildings... Even so, hardware is cheap. Labor isn't.
Including the labor of re-entering or re-creating lost data. Of
course, proper backup procedures can minimize this.
Enjoy,
DoN.
M
Michael A. Terrell
krw said:
"It" being the cat, I assume you mean. ...makes too much noise. ;-)
Then the fan isn't big enough! ;-)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
M
Michael A. Terrell
For real people that is a heel strap. You, on the other hand...
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
R
Rich Grise
I do it all the time, never had an issue with it. One thing I have learned
though is to stay away from optical drives with the air, more than once
I've stirred up dust which settled in and ruined the optics.
I put a finger or thumb on the hub of the fan blades - it kind of scares
me when they spin up to 1000's of RPM; some motors become generators when
spun.
Cheers!
Rich
R
Rich Grise
I suppose you've never heard of a special nozzle made for
electronics. It has a radioactive isotope to prevent static problems.
Microdyne leased two of them for the production floor, because the
manufacturer didn't sell them.
Central Florida isn't a desert, but I suppose you've never seen a
commercial air compressor with a dryer?
Of course it needs to be dried; every day we have to empty the
water out of the bottom of our compressor tank, probably because
the vapor gets compressed right along with the air, and condenses
out.
But I'd think it would take some heroics to actually _dessicate_ the
air; and I'd think that in FL there'd be enough ambient humidity
to drain off any static.
Cheers!
Rich
M
Michael A. Terrell
out.
If it's that humid in the plant, you have way too many problems with
the reflow ovens and toombstoning.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
C
ChairmanOfTheBored
Spelling lames? Hahahah... You're a joke, boy.
Try to stay on topic... wait.. you would have to actually know what
is going on to do that...
I
IAmTheSlime
spun.
Not when they plug into the wall, and have no permanent magnets in them
or no energized field coils.
M
Michael A. Terrell
No, you are the joke, and a consistently lame speller. You love to
point it out when others make mistakes, yet continue to make your own.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
R
Rich Grise
Years ago, I saw a guy take a new muffin fan - just the fan - and spin
it up with air.
I saw an arc.
Cheers!
Rich
K
krw
If the data is already lost, the repair tech isn't going to bring it
back without a lot of heroics and luck. The bottom line is: don't
lose data. It doesn't come back.
K
krw
Perhaps (noise(cat) + noise(fan)) is constant? ...like "all bicycles
weigh 25lbs., if you include the lock".
D
DoN. Nichols
Sometimes -- if the data has been entered from dead tree form,
it may still be around and can be re-entered. And if it is calculated
data from existing input -- that also can be re-calculated.
But that costs a lot more (in time) than proper backups. :)
Enjoy,
DoN.
M
Michael A. Terrell
I was thinking that if the fan was big enough the cat wouldn't go
near it, or would be blown out the exaust port, if it did. ;-)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
G
Gerald Miller
Last time I saw a cat go through a fan, it went in white and came out
mostly red.
Gerry :)}
London, Canada
