How many mA are required for a LOW and HIGH signal on a digital CMOS gate.
C
Chris
Mr. J D said:
I am looking at the datasheet for a digital XOR gate,
http://www.fairchildsemi.com/ds/NC/NC7SZ86.pdf . How many mA must be
applied to signal pins to make a LOW or HIGH signal?
Hi, Mr.JD. The data sheet tells you.
On the bottom of p.3, it says that input leakage current is +/-1uA max
at 25C, and +/-10uA over the temp range. It also says on the top of
p.4 that input capacitance is 4pF typical.
You should note that a typical input, like all CMOS logic inputs, has
an input current of nearly zero uA.
CMOS inputs in general don't have any DC input current -- you look at
them as small (pF level) capacitive loads. That can cause problems
with transition times, which can be an issue under some circumstances.
Good luck
Chris
B
Ben Jackson
Almost none. All you really have to consider is the desired rise time
vs input capacitance (4p) and the leakage current (10uA in that datasheet).
The input rise/fall time would dominate if you wanted to run the device
really fast, but even then something <1mA is probably plenty.
M
Mr. J D
Phil said:
** Groper alert !!
** But not seeing the bleeding obvious.
** Mosfets require no DC current at the gate.
Page 3 of the pdf data says:
Input leakage current: +/- 1uA max. at 5.5 volts and 25C.
....... Phil
Thanks for the insults, LOL. I knew that CMOS, because they are mosfet
driven, and not transistor driven, that they did not need a current.
However, you misread what I asked. What meant was does the CMOS see a
0V 0uA at the gate as a LOW signal?
John Popelish
You have to provide up to 10 uA of input leakage current plus whatever
is needed to charge the input capacitance of 4 pF as fast as the want
the input to change states. I=C*(dv/dt), where dv is the logic swing
(actually the swing needed to get from the minimum low state input
voltage to the maximum high state input voltage, or vice versa) and dt
is the rise or fall time you require.
P
Phil Allison
** Groper alert !!!!!!!!
** Then why the **** ask about one ???
** No I did not !!
** Which is NOTHING like your original question.
" How many mA must be applied to signal pins to make a LOW or HIGH signal? "
The data sheet has the answer to both.
......... Phil
M
mc
If it's CMOS, essentially none (something like 1/1,000,000,000,000 amp).
You have to charge or discharge the gate capacitance, which is a few tens of
pF (I think). Then no more electrons flow.
M
mc
Not reliably because there could be some leakage. There should always be a
path to ground, even if it is through many megohms, if you want the input to
see "low" reliably.
R
Robert Baer
Phil said:
** Groper alert !!
....... Phil
...and only because it is easy and *fast* to test for 1uA; typical is
in the low nanoamp region.
R
Robert Baer
You did *not* ask or say that originally.
E
Eeyore
It cares only about voltage.
0V = LOW
Graham
John Fields
That's not true. On edge triggered devices, the rise and fall times
of the inputs are required to be fast enough going from one input
state to the other to drive the outputs to their terminal states in
the time specified by the data sheet.
Since the gate capacitance of the inputs is what's being driven,
then, it also cares about current and, therefore, the impedance of
the driver.
D
Don Bowey
Thanks Mr. Captain Obvious.
If it was so obvious, why did you post the original question.
You come across as either a not-too-bright troll, or someone short of
understanding, but hates to be told anything.
