L
Lee Richardson
I apologize to the group for the repeat messages. D*mn computer must have
had an orgasm.
had an orgasm.
Lee, You have posted the same thing twelve times.
They all show up as 10:35 PM Sat. here in AZ.
Any chance you think the posts aren't hitting cuz your clock is broken?
GW
Lee Richardson said:If she does a lot of very short trip driving, you might do well to heed the
light and change the oil. The parameters it monitors to trigger the light
sound valid. You have to manually reset it, the method varies with make and
model.
It seems like it would be a trivial matter to put some kind of switch on the
drain plug or oil filter base that would trip when the plug or filter was
removed, and that signal could be used to reset the system.
http://www.speff.comSpehro Pefhany said:But that adds complexity and wiring, the "sensorless" systems are
basically free (just a bit of firmware) except for the light itself.
Best regards,
Spehro Pefhany
Bill Freeman said:Tend to disagree with your oil change mileages. Combustion is the
#1 progenitor of oil degradation (and I don't mean oxidation) and not
exposure to air per se. Heat resistance is part of the API & MilSpec tests
for oil validation (if you need a standards reference). The #2 cause is the
accumulation of combustion by-products washed during the lubrication process
that eventually degrades oil detergents and oil quality (i.e. the detergents
suspend dirt in solution). Hence the reason to change one's oil. Oils do
not "wear out" by oxidation and can be easily recycled >>
http://www.recycleoil.org/ &
http://api-ep.api.org/quality/index.cfm?bitmask=002001005000000000 .
Not bringing a car's engine up to temperature, dust, poor tune, poor
filters, dirty gasoline and oil pollution (e.g. broken coolant gasket) all
shorten oil life. In warranty, follow your "warranty recommendation" for
time and mileage. Out-of-warranty, synthetic oils can easily go 10,000
miles regardless of time. The advantages (most) synthetic oils have is that
they don't oxidize easily (are intrinsically stable), are HIGHLY
heat-resistant, retain their viscosity sheer range (i.e. they lubricate) and
leave few by-products (also known as "varnish"). They keep your engine
substantially cleaner. I agree with what you say about 5w-30 etc. on
synthetics. Try synthetics in any small 4-cycle engines you have .. .
you'll also see quite a difference from conventional oil.
Bill
