how does a PULSE code MODULATION WORKS?
Discussion in 'Electronics Homework Help' started by leonheard, Apr 7, 2013.
  1. leonheard
    leonheard
    12
    Jan 25, 2013
    will this work?
    1. I add in the receiver 4 D type flip flops, with clock input and the Data input
    2. I send the code from the IR transmitter example 1 1 1 0
    3. the 4 D type flip flops will “detect” the 1 1 1 0 signal (Wave length on/off time) in its INPUT pin, and its OUTPUT will be “exactly” the same code as the IR transmitter.
    dunno, will this somehow also work?
  2. Laplace
    Laplace
    1,252
    185
    Apr 4, 2010
    Is the IR transmitter/receiver designed for PCM transmission? Otherwise, how will you handle clock generation, clock recovery, and signal framing?
  3. Harald Kapp
    11,986
    2,808
