I was fed wrong information? This website says free radicals are
positivly charged. Find `positively charged` at this site.
http://www.healthenlightenment.com/principlesofdisease.htm
Radicals are not charged at all (ions are). Simply put, radicals are
unstable molecules, which quickly react with their environment and hence
can do damage to living cells.
Oxidation/reduction (redox for short) potential (again very simply put)
referes to the ratio of oxidising and reducing compounds in a sample.
Water from a mountain stream will contain a lot of dissolved oxygen
(which is an oxidising molecule), but little organic impurities. Sewage
as the opposite extreme will have a lot of impurities (which are
reducing), but little if any oxygen. Thus you can learn something about
the purity of water by measuring redox potential. This is done by
holding a special electrode into the water and measuring the voltage
between its two poles (which usually will be in the range of -2..+2 V)
with a milli-voltmeter. The meter must have a high input impedance, as
the voltage across the electrode would drop if any current were taken
from it.
For suppliers, check
www.WTW.com,
www.phmeters.com or general laboratory
suppliers like Fisher, Cole-Parmer or BDH. Good instruments can measure
redox potential, pH, oxygen concentration and temperature, and have a
rugged design for outdoor use.
