hey guys im new to this site and not really an electronics fundi but would really appreciate your help in this regard.
i need to build an electronic circuit which can switch a solenoid pump on and off repeatedly really fast to create the pumping force required.The solenoid operates on 12-14 volts dc and requires 11 amps operational current.In case you guys are wondering what im using it for,its for an aquamist pump on my car as i cannot get a replacement circuit board for it which was damaged by corrosion.Nobody around even has an idea how to build a replacement circuit.
thanks guys
thanks guys
