At least I think it is simple...
I have 2 12v wingtip lights that I need to be able to control with
one switch and one wire running through a wing in an airplane.
This is for just one wing. That's the gist of it.
I just bought piggyback strobes for the wingtips, but I don't want to
have them on all the time that I have the navigation lights on.
I was thinking of a relay that has a remote control, or has a signal
run through the positive wire or could possibly have a low & high
setting and if we send 12 volts to the relay it trips, but it won't
trip at say 10 volts.
Also was thinking about if I turn the switch on once just the light
comes on. Flip the switch off & on again in under 2 seconds and the
lights & strobes come on. Leave the switch off & everything turns off.
I was thinking about relays with a capacitor to keep the line live for
2 seconds to be able to flip another relay... but now I am confusing
myself again.
The ruggedized approach uses an SCR latch. The timing components are the
2.2U and 2.2M. If the circuit is switched on when the 2.2U is
discharged, T1 is triggered immediately and grounds out the gate of T2
preventing it from triggering. The strobe lamp remains OFF, and the 2.2U
charges to the battery voltage. When SW is turned off, T1 turns off and
2.2U discharges very slowly through the 2.2M with a 6 second time
constant. If SW is turned on before the 2.2U has discharged to
approximately 6V, T1 is prevented from triggering by the zener diode,
ZD, and T2 is now allowed to trigger and activate the STROBE lamp.
View in a fixed-width font such as Courier.
.. SW >---+------------------------------------------+
.. V strobe
.. - lamp
.. +----------------[1K]----+----------+ +-----+
.. [1K] | | | |
.. V | | | |
.. | [100] | | |
.. + | | | | T2 | |
.. === [2.2M] | | --- |
.. 2.2U| | +-[1K]-+---------\ / |
.. +----+----[100K]-----+ | | | --- |
.. | ZD |T1 | | | | |
.. | 6.2V | --- [1K]=== | [100]
.. +------|<|--+---+--\ / | |0.1U | |
.. [10K]=== | | | | ===
.. | |1n | | | | |0.1U
