[email protected]
I hope you'll forgive a simple query.
I have an audio amplifier module that takes 12v and an audio input, and
in turn drives a loudspeaker. Specifically, it is the module shown
on...
http://www.kemo-electronic.de/en/module/m031/index.htm
....and for what it's worth, I've wired ina 10k log potentiometer as
suggested.
I'm using this to amplify the audio output from a Garmin Quest ---
a small in-car GPS navigation unit. The audio output I'm using is
intended for use with an earphone. Using a multimeter I see that for
the duration of the announcements, the DC voltage across the output
rises from 0v to about 1v.
The problem I have is that <1s before and after the GPS makes an
announcement, the louspeaker makes a loud and irritating pop, and
I'd really appreciate some advice on what to do. By experimenting I
discovered that putting a 10 or a 100 micro-Farad capacitor across
the audio input to the amplifier removes the final pop and most of
the first one. It also reduces the volume. Since I don't really know
what I'm doing I'd be grateful if anyone could let me know the best
way to approach this.
Thanks and regards,
Jim
on...
suggested.
Thanks and regards,
Jim
