Help needed for microcontroller based project.
Discussion in 'Electronic Design' started by adam, Jan 7, 2006.
  1. adam
    adam Guest
    Hi Group,
    We are a group of four B.E students studying in M.h.S.S. COE, Mumbai,
    India. We writing to you to seek some help and guidance. Since this is
    our first microcontroller based project, we are unaware about the
    practicalities and methodologies that go into it.
    In our project, we have decided to use the following:
    AT89C52/AT89S52: MICROCONTROLLER
    DS1307: RTC
    MAX232/MAX485: LEVEL CONVERTER
    AT24C1024: SERIAL EEPROM
    4051B: 8:1 ANALOG MUX
    IC 741/ LM324: COMPARATOR
    LOGIC: 8 channels connected to the MUX, depending on which input is
    enables, MUX selects it and sends it to the COMPARATOR. The second
    input to comparator is a reference voltage. Comparator's output to port
    1.0. Ports 1.1,1.2,1.3 as selects lines to MUX. Ports 1.4,1.5 for
    intefacing with memory. Ports 3.0,3.1 as RXD and TXD. Ports 3.2,3.3,3.4
    for interfacing with RTC.
    Using select lines of MUX , we wish to determine which channel is
    enabled.
    using RTC we wish to sore the real time and pin number in EEPROM. Using
    RS232C we wish to display this data on a PC.
    We are facing the following queries:
    1. Is our logic correct? Are all the Ic's comaptible?
    2. Useful tips from your side.
    We are in the stage of preparing the circuit diagram and there are many
    doubts which occur. We would like you to suggest software for
    preparing schematics and layout. Is there some software available which
    directly converts schematic to layout? Please give names.
    The next challenge is the software side. In our syllabus we have learnt
    C/C++. Since some of you have mastered this, please guide us how to
    write the programs and routines and recommend compliers, simulators and
    other software related to programming. Are programs and codes available
    on net? If yes, Please give the resource locations or websites.
    Any help will be really encouraging and greatly appreicated by us. We
    look forward for some positive response.
    Last but not the least, we wish you a very happy and prosperous new
    year.
    Thanking you and with best regards,
    Adam Mashraqui.
    (on behalf of the group)
  2. Ian Bell
    Ian Bell Guest
    big snip
    You ask too much. Do lots of searching on the web for basic info. Do not ask
    for it here. For 8052 specific questions you should try www.8052.com
    Ian
