M
mpm
Anyone know where I can find a supplier for pre-made RS232 serial
cables with a DB-9 Male on one end, and a 3.5mm plug on the other?
Or...? Doesn't have to be 3.5mm, that's just the first thing that
comes to mind.
I'm on a new project that will need a serial port and want to shave
cost of the DB9 on the product end. (Also, tooling would be a slight
hassle as the PacTec enclosure I'm going to use would have to hacked
up a bit, whereas panel mounting a 3.5mm jack is no big deal.)
Ideally, a 3-foot to maybe 5-foot pre-assembled RS-232 to 3.5mm (mini-
phono) type plug would fit the bill. I only need TXD, RXD and ground
(common). How it pins out on the plug is not critical as it will
likely be panel mount anyway - although I suspect there's a "standard"
here.
Even RS232 DB9 Male to bare wire would be considered and I'll make the
plugs myself.
Not my first choice, however. But acceptable in early production.
Thanks!!
-mpm
comes to mind.
here.
plugs myself.
Thanks!!
-mpm
