Help amplifying a tiny current
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
Ouch, I didn't think the SSR's input Z (440Ω) was that low. Sorry about that! :oops:
Chris
hevans1944
Hop - AC8NS
Jun 21, 2012
4,887
Jun 21, 2012
4,887
Chris
Typically the SSRs have an LED in an opto-coupler input that needs a current limiting resistor. Sometimes they add an inverse-parallel diode across the LED to protect against reverse polarity. Depending on the minimum control voltage, there may also be a visible LED in series with the opto-coupler LED that lights up to let you know a control voltage has been applied. All this LED stuff requires a couple of volts and a few milliamperes of current to get the SSR output to turn on. Not usually a problem with control outputs that sink or source current because you can wire accordingly... but the 10 kΩ "pull-up" is problematical for directly driving an opto-coupler, and the comparator current sinking capability is a little wimpy too. The two conspire to require that a transistor be added to reliably control either a relay or the chosen SSR. That sucks. For a penny or so more the Asian manufacturer could have included the transistor on the circuit board. Caveat emptor.
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
I would think that paralleling the 10KΩ with a 1KΩ should do the trick and eliminate the need for an NPN driver.
Chris
hevans1944
Hop - AC8NS
Jun 21, 2012
4,887
Jun 21, 2012
4,887
Chris
It's worth trying. That would only add only six milliamperes to the sink current when DO is low but it would drop Vcc = 6 V down to about 1.8 V when DO is high, (6)(440/1440) = 1.8. That may or may not be enough to reliably turn the opto-isolator on. This is assuming the SSR control inputs are connected between DO and common. I vote to try it. Simple is always better if simple works.
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
Actually the 10KΩ isn't the only sink path between Vcc and DO. There's an LED and series 1KΩ in parallel with it. Personally I would try driving the SSR with the board as is. If the SSR needs more drive current I would jump the LED. This would provide a source resistance of 909Ω. With the SSR connected between GND and DO the LED would be a nuisance anyway. This is because it would never be off. It would just be brighter when DO is low.
Chris
Avondale
Sep 4, 2016
19
Sep 4, 2016
19
been tweaking around with other projects, but i now have all the parts for this, apart from the AA batteries lol
http://imgur.com/PWHa4Dn
here's all the pieces, just need to add some wires!
(did a little testing with these SSR's, theyre a little unintuitive, can't just put a multimeter on them to check that theyre 'on' or 'off', needs a load on them, and maybe a certain type of load to actually let them go 'off' when the 'coil'(not really a coil) current goes off)
further testing and soldering ahead!
but for now check out my other messy creation....
http://imgur.com/zjZRpVo
http://imgur.com/I9fTzl0
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Yes we probably should have warned you about the characteristics of SSR's
the great potato
Dec 2, 2016
52
Dec 2, 2016
52
theres a step up board that raises voltage i think was by 4-6 volt on wish.com for cheap maybe something like that might help?
davenn
14,265
14,265
but he wants to amplify current not voltage ;)
he hasn't been back for a month or so, so maybe the SSR method worked for him ?
the great potato
Dec 2, 2016
52
Dec 2, 2016
52
who knows maybe he hooked up a car batt and and a headlight and got his wanted results ! LOLo_O
Avondale
Sep 4, 2016
19
Sep 4, 2016
19
i actually never got this finished, i went off on other projects and decided to come back to it when i am far more knowledgeable about electronics lol
I got some normal relay boards for arduinos, will investigate their use of octocouplers to turn a small current into a larger current!
