W
Watson A.Name - Watt Sun
I made a hand cranked flashlight, sort of. I disassembled a defunct
NED CD-ROM drive, and used the DC motor and gear assy that opens and
closes the door, etc. I sawed off most of the plastic, leaving the
motor and five gears. For a crank, I screwed an inch long screw into
the cam gear, which when turned slowly, spins the motor fast. I
soldered a superbright red LED onto the red and black wires from the
motor and taped the LED to the frame (maybe epoxy it later).
Now I can just crank the big cam gear and the motor puts out enough
current to light the LED brightly. It takes two hands, so it isn't
really practical, but for the first try, it's pretty good.
Earlier, I took the motor by itself from another CD-ROM drive, and
soldered a red LED to it. I can spin the shaft and light the LED
brightly, but after a few times, the gear teeth make my fingers raw,
so it's not really practical. But it's still kind of cool.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
